I cant find the rock rod:D
Chrisblazzer89
Massachusetts 02301
OK so I bent my tie rod out wheeling today and I want to buy the Rockstomper rock rod but I can,t find it on their websight can someone help me??
I ended up going with a 1.5" tie rod from ord after finding out rockstomper no longer makes the rockrod. The unit from ord was kinda spendy but it's hasn't flinched at anything i can throw at it.
Chrisblazzer89 said:
Info on it plz. I don't want to keep bending tierods or draglinks or whatever its called
Tie rod. It ties the left side to the right, goes from left to right.
The draglink is the one that actually steers, the short one that goes front-to-back on factory steering (aka "push-pull"), from the box to the steering arm. (On crossover steering it moves from the box to the right-hand side, instead of left, to give more leverage and more even response when the axle is crossed up, which is why crossover is preferred to push-pull.)
And yeah, check out the WFO link. I got mine from Trevor, good guy, nice stuff, affordable.
-- A
rockstomper still shows it on there sight just no price. Thats where I got mine from. I'd try to call them again.
We make them as well. 1.5" x .375"
Trust me when I say that you will not bend or break these!
$120
Hell quote this thread and I'll knock $20 off for you!
~Max, NWF
Just to avoid confusion that price is for the rod itself without the ends. We can make it with TRE or Heims.
So a complete tie-rod w/ends and jam nuts you are looking at $209 minus the $20 - $189.
I'll let the 1.25"x.250" wall go for the same deal. So $179 complete minus the $20 - $159.
For the heims your cost will vary depending on the heims you want to use. Also for the 1.5" we will have to use a 7/8" shank as the id is 3/4".
So here we go a CK5 mini sale! :D :deal:
~Max, NWF
250-248-6024
I bent one. DOM tube tie rod 1.5" x .375". It's only slightly bent though and I still drive on it.
