Definitely a 205 - the rear output housings are also indicators.Couldn’t it also be a 203 case? I can’t see far enough over to see the idler shaft cover. Either way I agree that for the mix of parts you have Tom woods or a local shop building you one is your best bet.
From your pics, it's clear that at some point the front U-joint broke and the driveshaft hit the floor. The rear yoke is damaged and may be next to impossible to swap the U-joint in, the tube is junk and there may be additional damage to the front yoke. It seems like starting over is the way to go. If that's the case, it's time to look at your options. You seem to have enough lift that driveline vibrations could be an issue. That makes the following suggestion interesting:BTW, in the pics it also looks as if your rear driveshaft yoke has some damage near the cup retaining loop - have the shop look at it, they are fairly cheap.
If you can score one of these and matching flange from a junkyard, it will just need shortening. Here's a thread about it: https://ck5.com/forums/threads/ford-super-duty-drive-shaft.336467/swap in a super duty front shaft, the cv helps with vibrations
Sure, grab your tape measure and go: https://www.ebay.com/itm/2847453022...DCZQ3B&hash=item424c2480d9:g:hk0AAMXQlrxRdNn9So there is no chance of getting one from a junk yard or eBay or something? A direct fit without having to send it to a shop to be modified?
We can't tell you what will fit because you haven't even provided the measurement. Or do this:supply dimensions and application. length t case attachment slip, yoke, or flange, u join size.
If you're in a hurry, grab your calipers and good measurements of what you need and hit up wrecking yards that pile driveshafts up.
idk what those are but they look like front drive shaftsLength in pics. About 42".
To add to the concern if they are front GM IFS shafts be aware that they will have minimum slip travel as the front differential and T-case are fixed positions in the GMT400’s and up trucks and the shaft does not need to compress or extend except when being installed or removed.idk what those are but they look like front drive shafts
