4.88s??....1ton runing gear??? In a weekend warrior road truck that will see little offroad and towing a light boat?
Come on guys. He is not running the Rubicon or towing a house.
4.88 will put the guy over 3000 RPMin drive @65mph Not exactly great for a "Weekend road truck" Plus it will suck fuel like crazy.
1 ton running gear is way over kill.
Keep the 10 bolts and run 4.10 or 4.56 max. either one will be fine for his uses.
If the truck is more road use and fuel milage is a concern go with 4.10
4.10 will put him a little over 1900 RPM @65 in overdrive which will keep the 700r4 happy. In drive 2500rpm @ 65 which is in the middle of the powerband for towing.
I run 3.73's and I only have 33's. The motor is too low in the powerband at freeway speeds and the 700r4 does NOT like it. This is in my Burb and with no load. 4.10's would not improve it enough and keep in mind I'm only running 33's and not 35's. 4.56's would be ideal here and fuel mileage on the highway may actually improve a hair, though possibly at the expense of low speed mileage (slightly). Right now I actually get a little better mileage around town than I do on the highway, because the gearing just lugs the motor down too much.
