wilpetty
Should I try to get another or is this one good? I don't know the model though
Thanks for the info iceman. It was really dirty so I used carb cleaner and it came out really clean. How do I check if it is functioning properly? It is on the motor out of the truck so I can pull it off...when I pulled the levers the choke barely opened but the big flap didn't open at all. My dad said the truck may have to be running for it to open the flaps. Is this true?
You can check everything before you put it on the engine and have it ready to go.
But for the big flap only opens under load on the engine.
I used to rebuild these carbs and adjust them on the bench bolt them up and they would run perfect. I also tweaked one on my 79 van and got 17mpg.
What would cost of me rebuilding it be? I am not sure if it is worth it right now. I don't believe it leaks and I probably will just need to adjust it once I get the truck running and it will be fine. As far as performance goes, I won't get my bang for the buck of buying something else I suppose correct? I am looking to have quite a bit more power than the bad 350
If you haven't already, its worth getting the rebuild kit from Napa. That way you get a new accel pump and float jet and seat and all new gaskets. You will also be able to check float height and /or replace the float as well.
How difficult and long is rebuilding a carb?
put it on and run it..
Old motor coming out tomorrow and in with the new hopefully in a couple more days. I hope I am cruising around town in it by the weekend
