I have SIRIUS satillite radio
Z3PR
Banned
Everywhere
All hooked up and activated !!!!!! :D :D :D :D :D :D :D I like it, I like it alot. Mom gets too liston to her FOX NEWS, and I get too liston too everything else. :D This was one of my all time easiest installs. Mounted reciever box on the back of rear seat in trunk, plug CeNET cable into back of headunt and into reciever box, plug in antenna. Done with install. Activation was nothing but a few key strokes on the keyboard, and a credit card. The sound is clear as can be. If you don't have satillite radio yet, I recomend looking into it.
Got it for the wifes Impala on our Aniversary . Love it too , and now I want it in the truck :D
Sony is making a unit now , to plug right in to my XM radio deck , so I can have Sirius 12/9/2005 in my Blazer , it will look just like yours but have my plug :bow:
Need to do this before Stern moves.....Does your subscription cover all vehicles and house?
I move my reciever into whatever car I am driving and it has a base in the house. I love it. I think my subscription ends in January.
I only have the one reciever in the car. It's a add on unit in the trunk that's controled by the headunit.
Uses C-net cable too connect both units.
Sirius is great. The Howard's channels are too funny already, even though he is not officially there...can't get enough. The music selection is killer too.
Have a unit in Honda that I remove and take into work with me. Also am in process of installing one in my 69 this weekend.
Octane (sirius) 120 is great. Regular radio around here is mostly country.
I'm not impressed with the sound quality of my Sirius. FM actually sounds better. I'm running a nice Kenwood head and Sat. reciever. Anyone else have this problem?
Not at all, mine sounds way better then FM.
Did some more checking and found a few things
http://msnbc.msn.com/id/7150262/
Satellite radio sound is, at best, barely passable. That’s because your satellite service provider sends only one digital signal to your receiver. The receiver then splits that signal into hundreds of audio streams: some, for voice, very narrow; others, for music, a little wider. I’ve been told these streams run from a few kbps for voice to something like 30 to 60kbps for music.
A typical music satellite radio station is thus compressed and expanded at a much lower rate than many MP3s. A reader will write me to defend the sound of a 128kpbs ripped music file (it’s not near-CD quality despite what anyone tells you) but I can’t believe anyone can defend the sound quality of a 36kbps satellite radio music stream.
Compare that to the way a good FM station can and does sound. It’s not even close.
I just talked to someone with XM and he had poor quality too. I mean its not that bad, and still sounds decent but everytime I switch back to FM, or a CD, I'm like, WOW, this sounds much better. The lows are lower and high's are higher. And again, I'm using a $350 Kenwood head, with the standard Kenwood Satellite tuner that hooks up to it.
Finally got a pic of the unit I am waiting for . They pushed it back until after CES . I may be able to get mine after Valentines day ( pre-ordered ) .
Did you get the FM inline modulator switch thingy?
http://www.thesiriusstore.com/sirius-wired-modulator-relay-p-118.html
I am getting this for the car unit to see if that helps (cheaper than going to the Sony or similar units). I know it can be great because the system in the house is so much better than FM (I put the antenna on the roof with the cable extension/repeater).
I think the poor quality problem either has something to do with the head unit, or the FM modulator unit broadcasting to FM, i have the Sirius FM modulator unit (use it at work in the big truck) and actually think it sucks very badly,lots of static and hissing sound just like a fading signal from FM, i won't use it in my Burb, sounds like sheot.
But i have the ACTUAL XM receiver unit,( yes i have both) hooked into my XM ready Pioneer head unit, and the sound from that is MUCH better than FM, it is the same as CD quality.
I do not even listen to broadcast radio anymore, too many commercials, and just over sheotty sound quality.
and when did Kenwood sign on with XM anyways?
Our fm transmitting Sirius unit sounds fine ..... for what it is , a unit transmitting to an FM station that can only do 50-15,000 hz .
Remember , FM is 50-15,000 hz frequency response . With that being broadcast on FM , of course its not going to sound the best EVEN IF Sirius or XM were to broadcast the the full 20hzto20khz we can hear ( each sat channel is different ) .
No FM station on any radio , in the history of the world is ever going to go above 15,000hz or below 50hz EVER .
My Clarion headunit is Sirius ready and with the Sirius unit I have (No FM signal) it sounds great.
Thats why I pre-ordered the sir-sny1 , and I am daisy chaining my changer back into the mix ( until I get an mp3 cd changer ) :thumb:
Z3PR and Pauly,
Where are you getting your equipment? I want to go with Z3PR's favorite HU - DXZ945MP and the Sirius unit Pauly posted - do you still recommend both?
Thanks!
2Dogs said:
Z3PR and Pauly,
Thanks!
The DXZ945MP is Sirius ready. You will need This unit and you'll be good too go. Everything will be controled by the DXZ945MP. No extra display unit on the dash.
