I have to tow the Burb
where is your destination?
and dont even try u-haul UNLESS you lie to them about the rig goign on the trailer. also, you will have to supply your own tie down straps due to the ones on the trailer not being large enough for much else than a pass. car tire.
im not even sure if the u-haul wil be long enough. might have to flat tow it....
Grant
i think a flat tow would be the best. just going to have to go slow. or see if someone can tow it for you. nobody is going to rent a trailer to you that will fit the burban if they know thats what is going on it, and i dont think anyone has a trailer that is big enough to rent you anyway. hurtz may have one, but you have to use thier trucks with thier trailers....
Grant
I borrowed my buddies bulldozer trailer to tow my parts burb. The trailer was 16 feet and the burb JUST fit. So don't use anything shorter than a 16 foot trailer.
I can fit a full size long bed pickup on my 16' trailer with only about 2' of the truck bed/bumper overhanging. But it was built for a Jeep so it's a little narrow and I have to drive over the fenders (luckily they were built strong enough). The u-haul trailers would be about the same size but actually a little wider. But I doubt they have axles or tires as big as my trailer.
Flat towing is pretty easy to do, but the tow rig has to be bigger than the burb. Something like a 1 ton dually would be the minimum size in my mind. Then you have to remember you can't backup with a towbar.
:waytogo: made it through Texas driving it, I hope the rest of the trip was as good.
:whistle: (we spoke at Allsups the other morning)
Almost made it! Later that morning, in Stratford, the trans took a dump. Left it at Elk Service & Equipment. Johnny put in a fresh rebuild for under $1,000. Not too bad! Made it the rest of the way a week later, had to drive down and pick it up. Got her up here and now she needs a starter. Arrrr! It's cool, though. Totally worth it to have her up here
That bites,thats one long trip. In a small town like stratford you were lucky to get the tranny rebuild that cheap.
