blazin_blazer
ok, i blew my motor today....threw a rod out the side of the oilpan. i just came in from stripping everything off the shortblock....i had lifters blowed in 1/2 and the cam is broke also...jerked the rod out of the bottom of #5 piston and it went BOOM and poured smoke...i jumped out w/ my fire extingusher and no fire, guess it was 5 qts of oil on the header..and luck..ha yea luck!
i have vortec heads and carb intake that i ordered from gmpp and it pulled 1 of the rocker studs out some...so to reuse them i have to either take them to a machine shop and have them machined for screw in studs or buy the tool that lets you do it yourself, has any1 used this method? would i be better off letting a machine shop do it or is the tool fairly easy to use? or i could drive it back down and pin it, what do you guys reccomend?
looks like piston hit the head on a few cylinders, not sure if i bent any valves(or cracked a head), what is the best way to tell if i bent any valves? they look ok, ...but...???
should i just take them in and have them checked and tapped? not many miles on the engine(so shouldn't need valve job) i just over reved it going from drive to reverse to drive,i hit neutral, will have a rev limiter from now on!!!!
i pulled all my accesorries, heads and intake, didn't bother with the rest, i figure it is scrap, u can put finger down lifter bore up front and feel cam turn the cam doesnt move in rear, it puffed out my timing chain cover a little but timing chain looked good and was still tight, think it is still usable?
should i pull the rest of the engine down, think anything would be salvageable?
