Okay so I lost the keys to my new project. Best way to get around this for cheap or free??? am I going to have to take the column apart? This sucks I know I had them where the crap did I put them
Okay so I lost the keys to my new project. Best way to get around this for cheap or free??? am I going to have to take the column apart? This sucks I know I had them where the crap did I put them![]()
Unbolt ignition switch from the top of the column. Take off the rod that runs down the column. Stick a small punch in the rod hole of the ignition switch and slide it up and down to start/work the truck. Once you start the truck, you need to steer so for the locked column, you can take the steering wheel apart and grind the tab off the lock collar that enables the wheel to spin so you can turn. hth.
I just noticed this now but your title is a little off, I don't know if it's the keys that are stupid
This might sounds crazy, but have you tried just turning the cylinder by hand? I have a friend with a truck that starts without a key. Maybe you'll get lucky?
I guess Im one of the lucky ones cause I can just turn the switch and start her right up, key or no key!
