I need a big favor
Can Can
Pusher Man
Cochrane, Alberta, Canada
I need some info about the minimum front rotor thickness for a 1989 V3500 before you need to replace them. I would be very grateful if someone could possibly fax me the page from a GM service manual that shows the specs.
My fax # is 403-609-3282.
Thanks, brothers.
Thanks, brothers.
Paul..while I'm digging for this, I've forund a lot of websites that say the minimum rotor thickness is stamped into the rotor itself.. do you have them off the truck?
I use to have 3 books at my old work that had the specs.. but i can't find specs online...way too vague.
also this is a diesel right?
I THINK it's the 454 gas truck he bought recently.
Most of the brakes I've messed with have the value stamped into the rotor somewhere. If 4by4bygod can't get what you need, go to the local parts house and ask 'em for a rotor and see if you can find the marking.
ghettosmurf said:
1.480 (In thousandths of an inch) ;)
I have some brand spanking new bearing hubs/rotors sitting on the floor right beside my desk and I flipped one over to find the minimum thickness to read 1.465 also as you quote "in thousandths of an inch".
I just copy and pasted from the site i got the info from...people were saying they couldn't find anything "anywhere"
i would imagine the sites measurements are going to have a safe barrier to prevent from over turning the rotors.
And this was also listed for the V3500 with DUAL rear wheels...not sure if that makes a difference with singles or not. and i couldn't remember if his truck was 4wd or not,,,i thought it was though.
EDIT, i just went back and checked, that was the minumum Brake Rotor Specs (Min Machining)
Brake Rotor Discard At Or Under 1.465 (In thousandths of an inch)
Gm specs are as stated, but Dodge specs are 1.250". Funny thing is, they use the same caliper.
I worry more about pad thickness than rotor thickness on D60's--If it's over 1.250" and turns true, put new pads on and run it.
It is brakes, and they are important, but don't over-complicate it.
Jimbo
my 1990 R/V/G/P factory service manual says "minimum thickness indicated on rotor".. never gives a value. Handy, huh. Has torque specs for the nut that holds the ebrake release handle on though.
