I need a new trans maybe
jacksprat1599
Austin Tx
I think its dying.It appears to be leaking from the pan and doesn't want to shift out of first until obout 25 mph and then does so with a bang.Who makes a good replacement for the 700r4 if I need one.Oh,this one has 160k on it.
Sound just like the first time my 700R4 went out. I would say find someone local with a good reputation for building heavy duty tranny's and pay to have a good 700R4 built with all the right parts. Or Bowtie Overdrives makes some good trannys too.
I had mine built local. It was built heavy and has a 2yr/24K warratny. If I wouldn't have gotten the warranty I would have went with Bowtie OD's.
You might also be able to get a GM 700R4 for that too. Check your local dealer. They will be expensive but they carry a 3/36 warranty or 3/50 warranty. I don't remember which.
A good 700R4 isn't going to be cheap. Bowtie OD start at $1100 plus shipping. I paid $1600 for mine installed with the warranty.
$1600 was the going rate for a built 700R4 in Phoenix (installed) $900-1100 without install.
Harley
or at least thinkign th350 since it will go in place of the 700r4 about 95% directly, and they are common to find in good shape still /forums/images/graemlins/laugh.gif
it is a daily driver suburban not a rock crawler so I would like to keep the overdrive and isn't the th350 a weaker trans than the 700.
The 350 and the 700 are about the same weakness. Like was said before, you can get a bowtie overdrive with a great warantee for not too much more than a local rebuild. Just make sure you get a shop with a good reputation if you let someone local do it.
