I want to be done with my interior. (Dash, steering wheel, column, etc)
I need a victory cause this truck, along with many other things, is pissing me off. The problem now is that I can't get the shifter lever to move. Here's the details:
auto trans shifter
I rebuilt the column.
Changed to an XJ shaft.
Put gauge panel, new wiring, and everything back in.
So I'm not sure if it was something I screwed up.
So I took the xj shaft off. I've started to take the column back apart. I took the trans linkage apart at the top, so it's only a column now. The shifter arm at the bottom of the steering column seems kinda tight against the housing, but I can wiggle it. So it shouldn't be keeping it from turning. If it's tight, why is it up inside the column more now?
I can move the shifter a little, from park to maybe R or N. At first I couldn't move it at all, like it was locked. But the key works and after taking the shift linkage off, I can move it some. It feels like it's binding up as I move it. Unsure. There is no motor in it and I supported the trans before taking it out. I'm not sure when it stopped working. Before or after the shaft, or column rebuild, or gauges going back in.
Thanks in advance.
auto trans shifter
Thanks in advance.
