eh....
Inverters are OK for running a TV set,computer,and other lower wattage devices...but when you get much over 500 watts,I feel an inverter isn't the hot setup..you need several batteries,and the wiring gets complicated..also,if you want to run anything like an electric heater,toaster,or any other device with resistance wires that work on a dead short,the inverter will be straining,they are not really designed for that kind of use..and batteries drain fast with those kinds of loads..
One advantage to an inverter is you can get 110V without any engines running--for awhile anyway!..
I've seen guys use an electric motor ,rigged with some capacitors,as a 110V generator by making a bracket to fit it onto the engine,and run it off the fan belts..but they also do not power any other motors or heaters well either..If you Google "Induction Generator" ,you'll find a web site that shows how to convert a motor to a 110V ac generator quite simply....
You can also get 110v from an ordinary alternator,but it is three phase current,and is not 60 cycles,but more like hundreds of cycles per minute!--it will still power some tools and lights though..more info can be had if you google "Alternator Secrets",on how to modify a GM alternator to make 110V AC..
A bona-fide 110V belt driven generator that WILL power such things can be had from Northern Tool for about 300 bucks..OR you could rob one off a generator with a blown motor and adapt it to your engine..they are usually rated at 2000watts or more,enough to run most things in your average home all at once!...but you'd have to run your engine to get the AC juice...
They also have a line of 12V appliances available at most camping and RV stores,so you dont need AC current at all!--but most of the ones I've seen are pretty cheesy...
