Found i need half a ball thingy for stock shifter linkage
sweetk30
Back to play nice .
in the back of your brain
i need the white plastic half ball thingy that holds the shifter rod correctly in the frame cup . the big spring pushes against it to hold it centered .
all the trucks i have parted and i know i prob got 3-4 of them but were there at i have 100% no clue .
thanks for any help . 14845 zip code .
This would be the piece on the frame end of the pivoting shaft connected to the transmission shift shaft, correct? I have a complete 700R4 shift linkage set left over from my swap. It probably has what you need.
ya half a round ball of plastic with the hole in it .
its the big rod / spring / half ball / frame cup bolted to the frame rail .
i need the half ball thingy .
Mine is so worn that I didn’t know it started as half a ball. I’d offer it, but sounds like it’s roached.
just wish i had something like it i could cut down . . . oh wait let me check with my machinist in the am . he has lots of white plastic he turns for projects . he could prob whip me one up quick and easy .
