I need help finding a brake line!
eodcoduto
We could have been closer.
Muscle Shoals, AL
Does anyone know where to get the rubber brake line that goes from the master cylinder to the frame union on a 1972 Chevy C60 with the 9000# front axle? I have found all the other lines on rockauto, but this line isn't mentioned on any website or in person store that I have gone to. Its about 1.5" shorter than a front brake line on a '68 C10, the fittings are the same size but the internal diameter is bigger on the C60; rubber or braided is fine. If you have a part number let me know.
I have never seen a "rubber" flexible brake line from a master cylinder. Haven't been into any 72 C60 either. My guess, some Farmer did what farmers do and made something work.
I'm thinking it should be a steel line.
Or did you mean wheel cylinder ?
No this is factory, a hard line comes off the MC then down to a 8” or so rubber line that mates through the frame to the hardline that goes to the hydro vac slave cylinder. Finding parts for these is a pain.
You could have it made. esp if you have the old one,or a sample that has the correct ends. then just spec length and dia.
Found one, so once I finish the shademobile for the pasture I will get the brakes working and take this thing down the road.
