I need help now.. Pulling my engine
xsmokey11499x
lake elsinore California.
so as many you know. all of my problems I've had.. Anyway this will be my First time Pulling an engine.. I need to know What do I have to do, To remove the fuel lines.and the bolts on the tranny.
I think All I have left to disconnect is the throttle cable, TV cable, Motor mounts, Fuel line, and Trans bolts.
its pretty self explanitory. Take parts off motor till it is no longer attached to truck, then yank it out. Make sure you get all the wires off, and check once you start pulling it to make sure it isnt getting hung up. unbolt the exhaust too :P
exhaust was the first thing I did. I was just curious. I know I have to get the tranny bolts.. I have to have someone come do that for me, I can't get them myself >:O and how do I pull the Lines off the fuel pump looks like a pecial tool is req'd?
upper tranny bolts i use a double 1.5 ft extention.you can get a couple of them from.the parts store.then take the top cover off inside the cab if you can get to it.thats the 2 ways to do it.fuel line needs a line wrench so you dont strip it.that is all.make sure you disconnect all the grounds.there should be 1 or 2 on the back of the engine to the firewall.
