Nutro
Hi all! I'm new here. Not real new to squares but I'm always learning. I just bought an 88 K5 and starting to fix all the BS that the previous owner rigged and ruined. My newest project is t he steering column. I had my pops help me and we blew it apart and tightened down the 4 screws with lock-tite. I re-assembled it and it's pretty sloppy at the end near the steering wheel still. I';m thinking I should have replaced the bearings and found a new bearing race and crown as well. Does anyone have a good bearing crown they can sell me?
Also, on my high beams. I installed the paw correctly that pushes on the rod, I installed a new AC Delco multi-function turn signal switch and installed a new God awful-to-remove lower mounted high/low beam switch on the lower column.
When I actuate the high beam lever (Pull toward driver) I can see the rod depressing the plunger at the bottom of the column but I hear no audible CLICK and the high beams do not come one. I cannot figure this out.
Thanks, y'all!
Thanks, y'all!
