i need more gas
I have the same truck (1999 ccsb w/ 454) but I only have a 19'ish gallon tank. What are the dimensions on your tank? Maybe mine is bigger than I think. :confused:
btw I get 10-11'ish average with 245/75-16 tires, got about 8 with 34x10.5 ltb's.
im not real sure on the dimentions.but ive put 21 gallons in it before :D i get like 7 pulling my pig and 2500 pound trailer on the highway.i have 285s and 373s but im about to go to 410s soon
here is what im working with right now
this tank was partly used for towing
here is how much it took
the truck does have a small miss which i can figure out.if it sits for a week or so it will miss pretty bad upon start up then go away pretty fast.idles around 400 rpm.the truck has a new dist.,wires,plugs,air filter,fuel filter,ect
I decided to push my luck and went a little farther on my last tank, I stuffed 21.59 gallons in there. So I'm with you on the tank size. As far as MPG goes, you have me beat, I can barely squeeze 9 out of mine, but it's all city driving with short trips and no highway. I only travel 10 miles to work and 10 miles back.
