hahaha, really, I'm quite lost at this point of my project
I have a CA edition 85 blazer, has awesome carb and computer (selling if anyone wants) and lots of electrical connections I'm mulling through. I'm replacing with a different carburetor, different distributor, different vacuum system, different exhaust manifolds (lose the o2), and redo electrical.
The problem is all the vacuum and emissions stuff. I am looking to convert the entire "CA Blazer" vacuum system to a pickup system of the same year. My cousin's pickup is a CA native 3/4 ton '85, it has no computer or sensors of any kind. I would like to mirror this kind of system. Factory like
Problem with asking my cousin is, half the truck is in boxes currently.
I know the carbon canisters are different, carburetor vacuum lines, vacuum valves, sensors, etc etc. What would be the best way to change everything I have with stuff from an 85 pickup? I'm not worried about my heat riser, it doesn't work anyway and will be gutted, but the EFE valve on the manifold I might need. Can I use my old one even if it looks like it doesn't work? Same goes for my air injection, I'm saving the system, but probably need some new stuff for it too.
I dunno, can anyone help me please. Anyone from So Cal that will let me look over their truck and take notes? I'm currently working on a 400 sbc. I dumped the PO's Frankenstein 350, so everything is in boxes now. This is the reason I need a different carb, have everything work right, but still look stock under the hood.
thanks
PS> I have a shop manual I'm going through, but wondering if I should just order everything it says. Possible waste of $$
Problem with asking my cousin is, half the truck is in boxes currently.I know the carbon canisters are different, carburetor vacuum lines, vacuum valves, sensors, etc etc. What would be the best way to change everything I have with stuff from an 85 pickup? I'm not worried about my heat riser, it doesn't work anyway and will be gutted, but the EFE valve on the manifold I might need. Can I use my old one even if it looks like it doesn't work? Same goes for my air injection, I'm saving the system, but probably need some new stuff for it too.
thanks
