I need some measurements form a 6" lifted blazer w/241 sye
blazinzuk
Buzzbox voodoo
Rexburg Idaho
My jimmy is a 6" all spring lift. It has a 241. I am putting a SF 14 bolt in it.
My problem lays in the fact I am also going to be doing a sye my current driveshaft is not awesome and needs replaced. I have a CV driveshaft that will work with the sye. I need to know the angle of your output of the t case and the angle of the driveline I am gonna weld on the perches to work with the sye and just put up with it for a week. My axle will be moved back an inch over stock so the pinion length difference should be negligible
