phrogs
Registered Member
Think I have a knocking rod or piston slapping.. Help!
My 700R4 went out when I was driving from PA to Michigan damn mountains got my old truck. I burned up the 3-4 clutch pack everything else looked pretter good.
I knew I had the engine reving higher than normal but didn't really think about it to much I had a fresh oil change in it before the run.
Before I yanked the transmission out to rebuild it I heard what I thought was a low end knock or possible piston slapping.
Again I figured it might be trans related.
I got the trans in the other day got everything bolted up and took it out for a drive today.
Once I get to about 40-45 mph It is knocking bad, Can't really tell where but it seems to be passenger side bottom end.
I have no noise at Idle or if I rev the motor this only happens when a load is on the engine driving it.
Starts out like a tick tick noise and then hits in as a louder knocking.
Sugestions please.
I'm thinking New motor or at least a rebuild but Im sure I can figure out something better to put in the truck than the Old 350 TBI.
I checked the oil it is dark not real good looking has less than 2,000 miles since the change.
Could this be the knock sensor not working?
I haven't checked for codes because I have not had a Check engine light
Any other ideas to try and Isolate it?
I thought about jacking it up and putting the rear on jack stands then bringing it up to speed to get the noise and I might be able to pinpoint the noise with a listening device.
yawn
this sucks no truck for the winter months and I'm supposed to start a new Job in New Mexico. Kinda hard to drive my Corvette in the winter If I got caught in the snow I would be so screwed!
Sugestions please.
yawn
