bp71k5
3/4 ton status
I did the procedure to reset the IAC motor on my TBI-350 and found a clicking noise I'm not sure is supposed to be there. Here's the deal:
1. Jump the A and B terminal in the ALDL connector.
2. Turn ignition on, but don't start the motor.
3. Wait for 30 seconds then disconnect the IAC wiring connector...
When I go to remove the IAC connector, the IAC motor is making a fast clicking noise kinda like it's trying to open or close and is stuck? The noise stops when I unplug the connector. Any ideas what's up? I've got a surging idle again that I'm trying to diagnose.
Edit: Data logged it and the IAC counts are about 30-35. Seems they should be 10-15?
