Pump, tank, filter, fuel lines are all new, new plugs and wires, no vacuum leaks, everything is working and plugged in, truck has plenty of power and runs strong but it would not idle.
IAC port and pintle is clean and I did a reset on the IAC, it is working. Still would not idle. So I decided to do what they say not to do... I removed the plug over the adjustment screw on the TB to bring up the idle but first I placed an indicator on the throttle arm and set the dial to zero so I had the ability to bring it back to the factory setting. I backed out the screw so I could measure how far the arm moved down to the fully closed position but it did not move down at all. So there is probably some carbon build up that is keeping it from closing all the way or the screw might have backed out over time, I don't know. I then adjusted the screw so I could get an idle set and now all is good.
Right now I only need this truck to plow but I plan on fixing it up as time goes on. I just replaced the floor in it and I have one of the few rust-free K5's in Maine so its worth it go for a full rebuild. Just a matter of time.
Any way... that's what I did to fix it, not the correct process but I will go through the thing 100% some day. Thanks for the help.
