thfonz98
Recently replaced intake gasket(coolant leaking), TBI gasket, which has solved my varying idle in gear(dead on 500rpm perfect) but idle RPMs vary a bit still.
I also have a loud hissing coming from my IAC port with my air cleaner Assy. off, ran my winaldl and IAC is showing steady 39 till closed loop then jumps to 55 shortly after. No codes.
So as Ive seen, people ask if the IAC is hissing in previous posts but never address the response to said question. So this is my question: Hissing IAC port, normal?
91 k5 tbi 350, Odometer broke@ 218k (prob around 250k now)
