Iam A Member
DUK5
Registered Member
TEXAS
Finally I became a member seems like a good place to vist about oure passion for are blazers
passion....try addiction, im trying to get away from mine...but once I get a little bit away, i need that hit, you know....you gotta get some.
welcome man. lots of good info here.
year late and 25 dollars poorer but it's a good investment. i've already learned a thing or 2 on here and i've only been on since March
Yea, addiction !!!!!!!!!!!!!!!!
When I joined I had this :84' K30 /Big block 468/Dana 60/14 BFF T400/NP205
Now it somehow transformed into this :85' GMC Jimmy :Small block
357 cid (468 is getting freshened up & will go back in this winter)
32 spline SM465/NP205 /Dana 60 (lockright)/14BFF (welded till I can get a Detroit)/4:56 gears/Hdyro Boost brakes/ ORD X-over & High steer /4" TC front springs -ORD HD shackles & greasable bushings /ORD 4" shackle flip in back stock springs with greasable bushings /3" body lift /rear disc conversion (brackets from Dan @ Ruff Stuff)
/38"x12.50"x15" TSL's / Warn 9500Ti /custom front & rear bumpers /Kayline soft top.
