i hear alot of people mention using rv cams, do you think they are better than comp cams extreme energy series cams? i run a 268 comp cams xtreme energy in most my 4x4's b/c they have a pretty rough idle, but make alot of tq. which is kinda hard to get a lumpy idle w/alot of lowend power.
in my 2wd's i ussually run lunati's 284 bracket master cam, i once used the same lunati cam in a 383 w/10:1 compression in a truck that ran a timed mud run, but 1 of those 2 cams ussualy wind up in just about every one of my rebuilds, along w/p.a.w.'s piston specials($120 a set, advertised as cast 11:1 compression w/64cc head, i run 76cc heads, which should drop it to 10:1) sorry for the hijack, but i saw the rv cam mentioned and thought i'd ask about them and seems your question has a true answer, i wish arkansas had a place where a citizen could look up tag #'s, does that cali site give you the owners name? i've seen vehicles that i would like to know about and a site like that would be nice....
i think the 355 i'm putting together now is going to get the comp cam 268 xtreme energy, but i'm going to see if they will custom grind me 1 w/the 4/7 swap and try it out. again sorry for hijack
