Not that I'll have to deal with this again as the truck is now gone, but had an idea when Dad was working on his fuel setup and had issues with the (hard to find/costly/multiple variety) fuel tank switching solenoid. Someone check my thought process.
Given a dual tank truck of course, no emissions inspection, working sending unit/gas gauge. We'll assume the passenger tank is primary.
Rip out the switching solenoid. Connect fuel level wire from passenger tank sending unit to fuel gauge, bypass tank switch.
Run outlet line from passenger tank to fuel pump. Run non-vented cap on passenger tank. Run hose from fuel outlet on drivers tank to vent line fitting on passenger tank. Drivers tank vented through existing vent or vented gas cap. Fill both tanks. Done.
As the passenger tank will have vacuum as fuel drops, it will start a siphon from the drivers tank to passenger tank since the only "vent" is the line from the driver tank. Fuel level would always be correct, as the two tanks will equalize. Thus, fuel gauge level will be the overall level.
Just seems like a pretty easy/cheap solution to the valves and switches that are necessarily complex to meet a variety of laws that perhaps you may not need to meet. I would expect this would be easer on carbed setups that don't use high pressure lines, but with work I'd think you could do the same with any EFI setup.
Any flaws with this idea? I don't have the time to mock it all up, but I can't see why it wouldn't work.
..the gas gauge must stay on full a long time,then drop pretty quickly when you get to using up the gas in the main tank..
