88 k5 went thru frame off and now a dialy driver. Ran fine initially, develpoed a high idle thru all heat ranges. Braking would feel like the booster was bad. Brake light would come on anytime i hit the pedal. After it warmed up, i would tap brake pedal during movement and the light would go out...only to come back on when i wanted to stop. While trying to stop, the pedal would sometimes grab like normal but mostly like i had no booster on it at all. Sometimes, the motor would die. When i started it right back up, it would idle and run fine but the brake issue would remain under both conditions. Can anyone help me with this issue. During the frame-off resto, i turned a 79 block into an 88 motor by swapping in TBI and adding all the correct sensors to an 88 bodied blazer. Everything is hooked up as an 88 blazer. Thank you!
