skyhigh4by
Ok I asked a similar question several months ago but still haven't really sorted this out.
I have a tbi 350 w/ holley TB, salad bowl mod, Eddy intake, .450 lift cam, stock heads, headers. Fuel pressure is 17 psi, vacuum @ idle 21in/hg, timing 1-2 degrees, no knock sensor, no egr, heated o2. Its data logged, tuned, runs good, decent power, and excellent fuel milage for being on 38" tires. Mated to sm465.
Now for the problems... Start it cold, idles 1100 rpm until warm then down to 800 rpm(good) drive it a little, put the clutch in and idles at 1100-1200 rpm. keep driving, put clutch in and idles at 800 rpm. drive a little more, put clutch in and idles at 1200 rpm again. shut it off, start it up and idles at 800 rpm. drive it some more and idle will sometimes come up to 1200 rpm and sometimes stay down at 800 rpm. its totally unpredictable. the only certainty is that if i shut it off and start it again the idle will be at 800 rpm until I drive somewhere.
I just want the idle to always come back to where it should be.
The other problem which I don't know is related or not is that when sustaining load driving up a long hill in say 4th gear it will have a very slight misfire that can be felt but not really heard. A passenger would never notice it but I can feel it because Im so used to it being there.
I think the fuel curve in the tune could be adjusted slightly because its a little rich at idle and lean up top but overall the plugs are a nice clean tan colour. I bumped fuel pressure up until I got a happy medium between rich idle and lean top end.
TPS checks out, CTS checks out, IAC is new, MAP sensor checks out, Knock and EGR disabled in tuning.
While data logging at idle I have noticed that the IAC counts don't really settle and seem high to me.
Ideas please....
I just want the idle to always come back to where it should be.The other problem which I don't know is related or not is that when sustaining load driving up a long hill in say 4th gear it will have a very slight misfire that can be felt but not really heard. A passenger would never notice it but I can feel it because Im so used to it being there.
Ideas please....
