The IAC on Chevy's uses a cone, controlled by a stepper motor, = that pushes in and out of an orifice. Unplugged, it will just no longer adjust the idle speed. That stepper motor may have gone bad. There's also a possibility that the harness has a problem and the signal isn't getting to the IAC. Checking codes might show you some clues to go from. If it does have some fault codes in it, post them up.
