fried_guy
Registered Member
Ok, so I got my engine assembled and running.
No vacuum leaks, oil leaks, smoke, smells, odd noises, overheating, surging, etc... the only problem is my idle quality.......I think
Here's my combo:
406 SBC
5.7" Rods
9.1:1 compression ratio with 30cc dish KB pistons
670 Truck Avenger
Comp Cams Extreme 4x4 12-243-3 (270/278, 227/235, .480/.498, 111)
IE 200cc heads with the exhaust cleaned up
high performance ignition system
fully balanced and blueprinted
All new parts except for the block
all the bells and whistles, etc, etc, etc.
I can get it to idle at around 800RPM in neutral, but it's not the smoothest idle. Pulls 16"-17" of vacuum in neutral. Haven't checked it in gear.
Messed with the timing a bunch... doesn't seem to have much of an affect after around 18 degrees. Using vacuum advance on full source.
I tuned my idle mixtures properly... but they seem a little off. They really have almost no affect on the vacuum or idle quality unless I lean them out too much and it stalls. On most of the other engines I've worked on, adjusting the idle mixture screws seems to make a significant change in the vacuum. It seems that with this setup it's either too lean, or ok. No in between.
The vacuum seems good, but doesn't the idle speed seem a tad high?
Here's the only problems I can see:
1. I converted a dead head regulator into a flow through
-at idle the pressure fluctuates rapidly between 3-5psi
2. Using stock exhaust system
-don't know if it's clogged or how restrictive it is
3. Carb problems
-needs to be cleaned/modified?
4. I'm totally trippin'
-this is to be expected with the combo....
Any input would be great
Thanks in advance,
Casey
.Here's my combo:
406 SBC
5.7" Rods
670 Truck Avenger
3. Carb problems
Thanks in advance,
Casey
