Idler pulley
JOES89K5
Hello Members. I need information on the idler pulley that’s stationary (Not belt tensioner one) I have 1989 K5 Blazer 350 with AC. The pulley rear aluminum rear spacer that fits into pulley , bolt with recessed washer. Can anyone help with correct names and if GM part numbers or replacements. Any assistance would be grateful.
Hello Yes that’s the one but when parts guy at advanced auto went to order it come back out of stock it didn’t even have a part number since it was AC Delco. My original one is plastic but that don’t matter it’s probably an upgrade. I need part number.
https://www.amazon.com/ACDelco-15-20676-Professional-Conditioning-Pulley/dp/B000C984SE
https://www.rockauto.com/en/parts/acdelco,1520676,idler+pulley,6956
ACDELCO 1520676 {#19190145, 88919204} Professional; Smooth Info
w/Air Conditioning
EDIT for right ACDELCO part with AC
Wrong pulley but the back spacer might be the same. It fits into back of accessory idler pulley. The spacer sticks out back 1/4” inch.
Hello I found a AC Delco replacement. Fits perfect back on service.
What part number did you come up with? I’m at parts house now dealing with same issue. I have plastic pulley..all they have is metal. What ac Delco part number did you find that worked for you?
I got my pulley at oreillys. Iirc, it was listed as an alternative for my 91 and they had it on the shelf.
