if i do the 1/2ton to 3/4 swap-brakes?
only 31s
mass
do i need to change any of the brake system-[different master and such] or can i just swap and go -i know the 3/4 s are heavier can my 1/2 ton brake master handle it?Thanks truck is sub w/350,700r4 ,241+6"lift,35s[and soon hopefully 410s]
Don't even have to swap calipers, they are basically the same. Some 3/4 have a little bigger one, but don't think it's much of a difference. I did the 1/2 to 3/4 swap and kept the old 1/2 calipers, stopped fine.
I can stop my 1 tons with a Suzuki Samurai brake booster and a Camaro Master cylinder with no problem, and my rig weighs 4200 pounds on 42s
Did you just add the camaro MC onto the front of the sammy B/B?? If so what M/C? I have 88 sami and brake M/C keeps blowing out.
I think a late 70's early 80s Camaro works.
http://www.autopartswarehouse.com/sku/Chevrolet/Camaro/A1_Cardone/Brake_Master_Cylinder/1979/A1101521.html?tlc=Brakes%2C+Suspension+%26+Steering
You just have to widen the two bolt holes a little bit.
