Check out these two videos.
Having installed 1 terminator X, and 4 different sniper systems I can agree with this. Needless to say I'm a big fan of Holley.Ain't nothing but operator error. Break in you new motor with a good known carb. Then switch to the self learning efi.
i had help from a holly tbi guy and still couldnt crack the mpg i got from a used carb edelbrock 750 non adjusted over a pile of crap holley sniper unit for my new engine out of the box .Ain't nothing but operator error. Break in you new motor with a good known carb. Then switch to the self learning efi.
That is the main point of the videos is that these TBI systems do not learn fast enough, and wash out the cylinders during the most critical part of engine break in. Both videos came to the same conclusion..."Break in you new motor with a good known carb."Ain't nothing but operator error. Break in you new motor with a good known carb. Then switch to the self learning efi.
Nice. I didn't make it thru either of them!!That is the main point of the videos is that these TBI systems do not learn fast enough, and wash out the cylinders during the most critical part of engine break in. Both videos came to the same conclusion..."Break in you new motor with a good known carb."
