77snowwheeler
Patriot
Was curious? Knowing my ICM is getting hot, I have to replace every summer when weather starts to warm up. Everything Is new in ignition. Hei, plug wires are ceramic ends 8mm to protect against aluma coated headers. I read in a forum that there might be high resistance in the plug wires. I’m going to replace the spark plugs with new r43st, for cooler type spark. I usually replace ICM with AC Delco oem. If anyone has any timing advice, it’s a semi modified motor. The cam is 500/500. I was told it’s probably a little more performance than an Rv cam. So, with all that in mind, would love to hear some idea’s. Thanks in advance for any and all help.
