Try another key. The keys wear and don't work all the tumblers.
But it may be the ignition switch itself down on column, under the dash. The contacts can get worn and hang up the shuttle. You can unbolt it from the column and remove the rod from the slot. Using a punch that fits in the switch you can actuate it and see if it is hanging up, disconnect battery 1st. If the switch is not smooth and doesn't spring back from start to run, it's bad simply replace the switch.
While the switch is removed you can try the key and cylinder to see if it feels rough or catches. If there is roughness catching, come back here and we'll get deeper into column repair
