NEBlazer
Registered Member
I've been meaning to sign up here, I've been trolling for a while. So here I go!
I go to start my K5 this morning and the lock cylinder won't turn into the start position. It goes back into the accessory position and forward to turn the ignition on. Then it just stops like it's bound up. I took the actual switch off lower in the column to see if that was bound up. With the switch removed I tried moving the rod up and down to get the lock cylinder to move and still it still won't budge. Any suggestions before I tear into the column? By the way it's an 85 with tilt column and auto.
