BowtieBlazer
Diesel Powered
I posted this in the garage originally but am moving along here:
My 85 C-10 died randomly earlier this week. Very new 350 engine runs and burns clean no problems. No stuttering or anything before it kicked the bucket, just flat out died. Has gas, everything else seems normal. New alternator and battery. The battery is holding a charge. Since it died I replaced the ignition module. Nothing changed. I have 12V at the distr. cap but have no spark. Swapped over the cap and rotor from my blazer which worked when I took it off to test it on the C-10 and still works when I just put it back on. Even with the working coil I get no spark at the plugs.
That rules out the coil.
Correct me if I am wrong but the rotor when you turn it over is supposed to stop in the #1 position of the firing order (1-8-4-3-6-5-7-2) Its stopping exactly 180 degrees of where the number one plug goes on the HEI cap. Does this mean the timing is off? Everytime I turn it over it stops in this position. Couldthis be why it doesn't start? How do I fix this? I have no experience with adjusting timing or anything. PLEASE HELP! /forums/images/icons/confused.gif /forums/images/icons/confused.gif
