badmix
My truck seems to be suffering in the gas mileage department. ANyways. I wanted to check the carb and do the vacuum gauge tuning. I leaned the carb out a lil bit and then had to adjust the idle. The gauge then indicated incorrect ignition timing, so I decided to check it with a timing light. The Line on the Balancer was WAY off to the passenger side of the dial bar thingy. So I adjusted the dizzy and with the timing light. The emissions sticker said 4degrees of timing. On the bar thingy mounted to the engine itself. Ive got a peep hole and then the bar itself has 0, 4 & 8 with lines inbetween. Now am I to assume that 4 degrees of timing means I put the harmonic balancer line on the 4 pointer bar?? I did this and then had to do some carb adjusting, but I think ive got it all sorted out. yea for carb motors.
. lol. Anyways, just want to make sure im doing this correctly.
