Hello crazy K5ers so I need some help. The PO hotwired a line from the dizzy to the ignition because he couldn’t get it to fire. I’ve attached a photo to explain what I mean. I wanna fix the issue and do away with the hot wire. Under the dash I have the hot wire connected to I’m assuming the key ignition wire. In the pic you will see the hot wire the hot wire that runs from the dizzy to inside under the dash. The K5 is an 86 but has a late 70’s 350 but the distributor is the one from the 86. What’s happening and how do I fix it? Also what are the extra wires I’ve attached in the pics? I’m trying to find the hot wire for the choke and have no idea which is which. Thanks for any help. And ask questions if this is confusing.
