pontiacratrod
Registered Member
thinking that the ignition switch was the cause of my starting problems, i replaced it last weekend. shortly there after i realized that it was a bad starter. i put the old switch back in but ever since i cant turn off the truck in anything other than park. the key physically wont turn to the off position in drive, reverse, nuetral. nothing. also, when i turn the key to ignition it sticks and makes that noise you hear when you try to turn your car on when its already running. im confused because i put the key in the off unlocked position and set the switch to the second detent (which is off unlocked). ive tried setting the switch in a couple different positions, and it wont even fire. im confused. really confused.
