MassMan
It has been a while, but I'm back for more! My hunk of junk is finally running well and moving under its own power thanks to all the help I got here.
Recently, after a full day of pulling logs and brush, I noticed oil running off the bottom of the pan. The starter was soaked and oil was burning off the passenger side exhaust. After replacing my valve cover gaskets I finally tracked it down to a rust hole in the oil pan right next to the starter motor.
After looking at replacement oil pans I have a few questions. It looks like I need to know if my engine is a 1 or 2 piece seal, whatever that means. When I bought the truck I was told it had a relatively new, dealer installed, GM Goodwrench 350 (it replaced the original 305). Now, I just scraped off enough grime to see the casting number and it reads 3970014, which was supposedly made anywhere from 1968 to 79 and could have a 2 or 4 bolt main (whatever that means). Is there any way to tell what type seal I have? Is there anything else I should know when shopping for oil pans? Is my engine really a rebuilt block from the 70's? I wish I knew a thing or two about engines, but that's why I have my membership here. So many questions, so little time...
