cabledawg
Secret Squirrel
Onboard air and air control for the airbags. Anything I'm missing? I'm pretty sure I'll have all the bases covered. One switch for the compressor (still might add a pressure on/off switch), one for the fill solenoid and one for the bleed solenoid. Front and rear outlets so nothing is ever too far away from the air line. Both gauges will be on the dash, one for tha tank pressure and one for the bag pressure. Check valve to prevent loss through the compressor. All using heavy rubber air hose instead of PVC tubing.
