Took the Blazer out to test the front axle and moved the transfer case shifter now it won't move
Start backing up, push in the clutch as soon as you start, shift the T case while its rolling.
If its an auto, reverse, neutral, shift while rolling.
If not, try it going forward.
It may be stuck in neutral. Shut it off and put the tcase in the desired gear the the trans in park. Then recrank and go for it.
OH Crap!!
I completely misread the first post.
I thought the shifter was stuck..........
Chock the wheels, put the transfer case in 4wd, turn off the engine and put the transmission into park.
Now crawl under and try to turn the drive shafts. If they both turn together, then the transfer case has come disconnected from the transmission, or the tranny is bad.
Wait, that won't work, you would have to jack up both ends to try that......
Are both driveshafts hooked up?[/QUOT
Yes both shafts
