I'm too lazy to go outside...
thatK30guy
1 ton status
...and its too cold and dark to check for hole distances on a K5 and K30 frame.
I need to know if the very rearward rear spring hanger bracket, the shackle end, has the same distance between the rivets/holes.
In other words, can a 1 ton rear hanger bolt right in place of a K5 hanger without redrilling more holes?
Or will some holes have to be drilled out?
With todays temps at 57, I went outside and did some measuring.
Turns out the K30 and K5 rearward hanger rivets are the same locations. 6" across and 2 5/8" down.
Now I need to make a post in the Wanted forums...
