EdPDX
Registered Member
My army Blazer runs and starts fine but now with the cooler weather I am noticing the transmission (I think) is slipping when I first start it in the morning (Or whenever it sits a few hours).
I warm the engine a couple of minutes and shift through all gears (Auto trans). The vehicle does not move in gear either direction. I slowly give it a little gas and in a few seconds I can get it rolling. Once I'm under way it get progressively better each time I stop at a light or sign.
When the transmission has been working for about 5 minutes it runs as it should- there is a hint of slipping- then it catches and runs well.
I am new to diesel so I am wondering if this is due to low IP pump pressure- changed to a new green line Fram modulator- no help. Is this a possible IP issue? A VRV Issue... or is it strictly a slipping transmission issue?
I dropped the pan today. The plastic tube that runs from the filter to the transmission was a little sloppy. I changed the gasket and filter and bought two slightly larger O rings- put them both on and could feel a serious seal when the tube went into place.
