I am going to build a 400 for the wifes truck 92 k2500.. it has lazy gears(3.73 33 inch tire) so I am not delusional in what the engine sees for rpm.. figure towing 3rd at 55 its 2300-2600 depending on if the converters locked or not, and when the truck is in OD its cruising 2k around 70-80 so I need something that pulls low..and max will see maybee 4800 or 5k if I tweak the chip to allow it..
So.. my proposed combo is something like this.
400 .030 over
stock rods and crank with arp rod bolts
comp XE256H (per their recommendation)
Vortec heads
Edelbrock tbi vortec intake
some sort of roller rocker
9:5-1 or as close as I can get.
long tubes or try y headers.. It has shortys right now..
the only thing I am hem hawing about is the heads and intake. I can get dart iron eagles for $995 and they are thicker casting (better for heat) and have a better I/E ratio than any vortec head so the power is going to be better. I dont know what a set of vortec heads costs new with the intake.. I have to imaging 6-800?? plus the 300$ intake.. so I figure a swapmeet standard chevy intake and those darts it will be all the same pricewise..
Any opinions? suggestions?
400 .030 over
Vortec heads
