Increasing front brake hose size opinions *DELETED*
Re: Increasing front brake hose size opinions
I had always been told that they are supposed to be stiffer, better. Then a little bit-o-bling as well. I don't own either (a corvette or stainless lines) but it would still piss me off. I could never buy new. /forums/images/graemlins/thinking.gif
Guess it's built not bought for me /forums/images/graemlins/whistling.gif
holy crap, are these the hydralic hoses you were talking about or are they really street legal brake hoses??
Not DOT approved.
THESE ARE NOT STAINLESS HOSES. I WILL NOT USE STAINLESS HOSES.
These are teflon braided hoses. I'm sending them back. Aeroquip says that they can get me the correct -3 lines in 6 days this time and that they'll refund my money for these.
I have the IFS hoses now. I almost ripped them apart before I extended my lines with steel. Now they're a mess. Besides that, I want to secure the hose to both the axle tube and the shock to prevent it from ever being snagged on anything. They'll be really cool when I get them installed and I'll post up pictures.
I don't see a problem with these lines being longer than stock. They're rated for four times as much pressure as a brake system is capable of producing IIRC, and it's doubtful they'll swell. They're much, "stiffer" in construction than stainless braided DOT hoses.
Can you give us an Aeroquip spec or part # for these?
When you say "teflon braided hose" and "not stainless", I assume you mean a teflon liner surrounded with a braided nylon sleeve. Correct?
Line size doesn't matter... it's the piston size on each end of the line.
I think they use small lines because then they can get more fluid displacement and get fluid out of the hot caliper. I could just be imagining this too.
Tube & hose size does matter, a LOT! In steel tubing there is almost 2.5 square inches more surface area per foot with -4 or 1/4" tubing over -3 or 3/16" tubing. It is nearly 1/3 of another front caliper piston's area. That's a lot more surface area that will deflect. Deflection = mushy pedal. Put your hand on your rubber brakes hose and have a buddy stand on the brake pedal. That should show you that small is good. Going too far and trying 1/8 will not flow enough and cause a delay in brake application.
Don't use -4 for brakes in passenger vehicles, it's OK for hyd clutches. Bigger trucks, like 5 tons, use 1/4" hoses b/c of the large wheel cylinder volume.
I didn't write the first part so I don't know what the f' you were thinking.
I picked both of the bad sets of info and compiled them. Didn't mean to infer that you wrote any or all of that.
Hose diameter only matters outside of reason. It's the length of the hose that matters more. If your hard lines expand any noteworthy amount you have issues. If you're using crappy hoses (such as most cheap wannabe stainless braided ones) then get some stock ones.
No, yes, and yes. It is the total surface area in the system that is important. Diameter and distance be danged, although they are what determines the surface area of the conduit. You want the lowest ratio of non-working surface area to working surface area that you can get, w/o crossing over into such a small tube size that you can't move the needed volume.
The slave cylinder moves a set distance...
The amount of fluid needed to move that set distance doesn't change...
Therefore the master cylinder need not move any more fluid...
The only thing that changes is that the fluid in the line physically moves less distance...
That ignores the not quite insignificant amount that the steel hardline will grow under pressure. Steel hardline grows under pressure at about the same rate as -3 braided stainless hose does. That growth shows up as lost motion or mushiness at the pedal.
It seems like in my readings years ago I read that brake hose specifications were based on increase in volume per unit pressure. So even though a hose might be larger in diameter it had to meet the same specifications in expansion as a smaller hose.
Expansion is a function of area and the strength of the material(s) in question. If the expansion of a larger ID hose is to be held the same as a smaller hose the material hte large hose is made of would need to be stronger. Which it is not w/o changing types of hose. Look at what the rated service pressures are for any hyd hose as compared to the size of the hose. As each type of hose construction increases in size the max pressure decreases.
Anyway, keep the hoses short. If I were a rich person I'd probably use Earl's Speed-seal ends and Speed-flex hose.
Good advice. XRP is also good stuff.
The funny part about those aeroquip or earl's ends is that they CAN'T meet DOT requirements because the ends aren't swaged or crimped on. Even though they're a superior way of fastening.
To my knowledge there is no DOT requirement for how the hose is actually constructed. There are three performance tests in the DOT test. Braided Stainless hoses easily pass, and do better than OE type hoses in two of those tests. The third test is designed to fail braided stainless hoses which is why all of the DOT legal braided stainless hoses have some sort of strain relief around the braid right at the sleave.
From my former Design Engineer employer: web page
can we change that to "DOT compliant"
personally I could give a rats buttocks what the DOT approves of
from the link posted by ntsgd
We recommend use of high quality -3 or -4 braided stainless steel flex lines as replacements to the stock rubber lines
so run the -4 and fugetabuttit
If you dont kind me asking, how much did these lines cost you??
-Chris
If I gave away the part number I'd kinda be a fool considering then I could not sell them. /forums/images/graemlins/frown.gif I give away part numbers for damn near everyhing but honestly, I'd really shoot myself in the foot if I did this, so I am sorry I'm not going there on this one. I shouldn't have even mentioned the brand name to be honest, it was out of line for me to do that in the first place.
Spec is -3 AN to -3 AN, 40" long, and some adapters to use 10mm banjo fittings and for the 3/16" IF brake line at the top, plus a way to retain them in a stock type bracket.
They are teflon hose with stainless braiding. What I meant was that they are not stainless over rubber like the majority of aftermarket lines. They are not DOT legal but they're available ANY LENGTH. If you wanted to buy enough adapters you could do your entire truck in flexible line with this stuff.
But, it took me two months to get this set and it's doubtful I'm going to get a set in 6 days like they told me, so I guess it doesn't matter anyway unless someone wants to wait two months for a damn brake hose, which me personally, I'm tired of farting around trying to get the damn things, I just want them to be here and installed on my truck so I can see how they work.
1. The manner in which the fittings must be attached to the hose.
FMVSS 106 specifies that "Each hydraulic brake hose assembly shall have PERMANENTLY ATTACHED brake hose end fittings which are attached by deformation of the fitting about the hose BY CRIMPING OR SWAGING." [Emphasis added]
The idea is that, since crimped-on fittings can't be loosened, a stupid end-user won't be able to screw with and weaken them.
This is a good thing from a product-liability point of view, I guess... But it means that any hose assembly which uses the very best fittings available - - like the nipple-and-cutter Aeroquip Super Gem or Earl's Speed Seal -- is non-conforming and CAN'T be DOT-approved.
Source Here, near the bottom.
From the URL I SPECIFICALLY pointed to:
"Q: What size brake lines should I use?
A: Use 3/16" steel line wherever possible. Use flex line only where necessary."
So run the -4's. See if I care, BUT when you have mushy brakes I'm going to be a real prick about saying I told you so.
BTW, the FMVSS is not the same as DOT.
I quoted the next question of the URL you specifically linked to
Q: Will stock rubber brake lines work with Wilwood Brakes?
A: Yes, but they require 1/8" - 27 NPT adapters to fit the calipers. We recommend use of high quality -3 or -4 braided stainless steel flex lines as replacements to the stock rubber lines.
do you really think anyone here is going to notice the 'mushy' brakes in these trucks?
If they don't, they're not very in tune with their truck.
Not doing anything special? Nobody else thought of it yet!
Jeeze.....sorry I even asked.
most of the population cannot tell if they lose the rear brakes entirely
so much so that the factory put a red light on the dash to tell them about it
yet they drive around ignoring it for months
chev brakes always feel like mush to me
why delete posts? Somebody hurt some feelings? There is (was) definitely some useful info in this post, but now that the original ? is gone, those doing a search a few months/years from now will come up empty, prompting more questions. Just leave it up, so folks can learn. /forums/images/graemlins/screwy.gif
You guys all missed the exchange of words this afternoon.
Either way I'm going to have some purdy -03 lines next week, and 40" is LONG!!!!
They'll be nice, just stay tuned.
We shouldn't, b/c of our use of our vehicles, be "most of the population."
