JohnyWard
Registered Member
I figured I'd check around and see what everybody had done. I am just about to finish up plumbing on a disc swap on a 14FF and wanted to know what people were running from the hard line to the calipers.
Here's what I am committed to:
Front calipers from a 73-87 chevy
And I would really like to use a 3/16 hard line from the Tee. This also means that the soft line would be around 10-14" and be a 3/8-24 on one end and a banjo on the other. But if there is any compelling reason I should reconsider I definitely will.
So please any suggestions with costs are much appreciated and part numbers would make you a God-send.
