mpascino
Our latest addition to the product lineup! This kit replaces the factory cast adapter and allows you to clock your tcase in ANY orientation desired. Recoup some coin by selling your old adapter.
Full spline engagement is maintained, unlike clocking plates that bolt between the factory adapter and t-case. Simply weld the components together in the orientation preferred. Hardware is included. Additionally, a mounting plate is included for you to use when building your cross member (We typically would use tubing with bushings mounted at the chassis but that's up to you). Shown below is a TH-400 to figure 8 205. Accepts factory seals and gaskets(Which ARE provided for TH350/TH400 figure 8 setups). We can produce all of the popular GM combos. Custom/non GM configurations are possible with some additional input. Install a transfer case on your 2wd transmission by just removing the tail shaft! Contact us with any questions or needs. We can help you work through any shift linkage if needed as well. The adapter shown below is $295 shipped to your door. Contact us for alternate configurations and pricing.
Thanks,
Mike
Trail Tech Fab
Clocked Up
Clocked Down
Full spline engagement is maintained, unlike clocking plates that bolt between the factory adapter and t-case. Simply weld the components together in the orientation preferred. Hardware is included. Additionally, a mounting plate is included for you to use when building your cross member (We typically would use tubing with bushings mounted at the chassis but that's up to you). Shown below is a TH-400 to figure 8 205. Accepts factory seals and gaskets(Which ARE provided for TH350/TH400 figure 8 setups). We can produce all of the popular GM combos. Custom/non GM configurations are possible with some additional input. Install a transfer case on your 2wd transmission by just removing the tail shaft! Contact us with any questions or needs. We can help you work through any shift linkage if needed as well. The adapter shown below is $295 shipped to your door. Contact us for alternate configurations and pricing. Thanks,
Mike
Trail Tech Fab
Clocked Up
Clocked Down
