myraley
I just wanted to post this info, so no one else would need to do the research like I did. If you want your evap charcoal canister to work (the round kind), here are some photos and some info. If your have a quadrajet carb that does not have a vent hose from the fuel bowl, you will want canister # 7030605. It has three hoses coming off of it. One to a PORTED vacuum port on the carb, one to the PCV and one to the fuel tank. The vapor comes from the fuel tank, sits in the canister until the ported vacuum is applied and then enters the PCV.
